bcole66's avatar
bcole66
Voltage to gas valve?
I recently (last night) installed a brand new 10 gallon Suburban hot water heater in a park model in the campground where I am currently staying. (For a friends park model, not my travel trailer) The problem is there is no 12V available in a park model, and the new hot water heater is DSI ignition and requires 12v. I had purchased an inexpensive 120v/12v step down transformer from Grainger and mounted in in the compartment right next to the heater. The heater fires, but the solenoid valve rattles like crazy and the flame is erratic. I initially thought I had a faulty gas valve but then I noticed the output of the transformer is 12VAC and the gas valve is 12VDC! Any thoughts or comments on how I can provide 12VDC to my hot water heater?
  • install a heavy duty diode in the line. Maybe a capacitor after the diode. Make sure the polarities are right It should work OK.
    Go to:
    www.circuitstoday.com
    Or google halfwave rectifier. You don' want a fancy power supply or need a battery. Use that transformer and add one diode and one capacitor.
  • Knowing this was a park model with no 12 vdc system I'd have added a small 12 volt battery and perhaps a battery tender to maintain it.
