davehultin's avatar
davehultin
Explorer III
Apr 24, 2014
Vortec: Too much engine? (Mileage questions)
Hi,
I'm getting dangerously close up upgrading my 1999 Yukon with a 5.3 engine to a 2007 Yukon XL with a 6.2 engine. I was test-driving it today and saw the display list an average MPG of 11.5. Yikes! I'm second-guessing myself if I should have that much engine.
It's sole purpose in life will be to pull our camper, which is about 4500 pounds. I'm sure a 5.3 or 6.0 would be MORE than enough, but I'm wondering if a larger engine like the 6.2 will actually be more beneficial (in terms of mileage) when I'm pulling a trailer.
In other words, I know my 5.3 drops from 15 to 10 MPG on the road when pulling a trailer. Will the 6.3 have less of a drop because it's not working as hard? Will is also come in around the 10 MPG range?
This is a really beautiful truck, but I'm gonna kick myself if I get it and have to spend all my camping money at the gas station...:(
  • If you get a 6.0 in a 2500 4X4 be prepared for 7 ish towing and tops of 12 ish empty. That's what I got with my 2011 2500 Ext Cab 4X4. Great milage and towing never relates. I believe I'd roll the dice and go with the 6.2 which I believe is all aluminum? Couldn't find one when I traded trucks and no 3.73 until later this year. Went for the Ecoboost and am quite satisfied. This is a former 2012 6.7 Ram owner. JMHO
  • I agree with APT, all gas engines suck unleaded at a pretty good rate when loaded heavily. There wouldn't be that much difference in mpg when each was towing, but the 6.2L would be a better performing tow vehicle as it has more power and the 6 speed.
    I can't comment on the AWD system.
  • Thanks for the input!
    APT wrote:
    I personally do not like the AWD system mated to the Yukon Denali.
    I've never had an AWD before ... what's good and bad about it, both as a tow vehicle, and as a "regular" vehicle?
  • All three engines will likely get the same FE as your 1999 5.3L when towing. The 6.2L/6-spd combo will be a rocket compared to what you currently have though. unloaded fuel economy shoudl be similar to your current truck too. We get about 2MPG better under all conditions in our 2011 3/4 ton Suburban than our prior 2003 F-150, with far more power. If this will be a dedicated TV, I highly recommend a 3/4 ton. But for your weight limit, the 6.2L should be fine. I personally do not like the AWD system mated to the Yukon Denali.
