DReisinger wrote:
I am installing a MaxxAir fan in the bedroom ceiling vent of the fiver. The instructions say to remove ALL old sealant from flange mating surface, is there anything that will make this come off a little easier?
Yes, 3M caulk remover. Apply the remover, cover with plastic wrap and let it work overnight. The next morning, if applied correctly, the sealant can be removed with a rag. Follow up with solvent on a rag and then soapy water. Rinse, dry, and then, the new flange with sealant can be installed.
