GWolfe wrote:
If your pup weighs 2700 lbs you should have a tongue weight of at least 270 lbs, you shouldn't be able to pick it up easily. My 8' pup had a tongue weight of around 200lbs before I added the extension, I have never had a problem with sway.
You need to get more weight up front a WDH is not going to help with a light tongue weight.
I didn't mean to imply that I can pick it up easily. From the feel (comparing to deadlifts at the gym), it's definitely over 225 lbs. . . probably over 245 lbs.
