RavensFan24
Apr 17, 2016Explorer
My Premier isn't a walkable roof, but I've gotten up there a couple times. One tip is to use a piece of plywood to spread out your weight. Mine is also TPO and not Rubber. I haven't had to clean mine other than spraying it with water thus far, but I'd be careful about using rubber roof cleaner if you don't have a rubber roof. Not sure if your Premier has the same TPO roof as mine, but just wanted to make a note of it in case.
44,056 PostsLatest Activity: May 04, 2014
