98coachman
Sep 02, 2013Explorer
Welcome to the forum. If it is directly under the window I would pull out the window and try to put resin into the bulge through the edge of the window opening. It should be delamed all the way up to the opening. Make sure you allow it to dry out before you attempt repair or it will note adhere. After you get the resin in the bulge take two boards and clamp it together and allow it to cure for a day before removing them. Get new butyl tape and reinstall window.
Good luck,
Bill
Good luck,
Bill
