LarryJM
Mar 04, 2015Explorer II
pira114 wrote:
If there's foam inside the wall, the molly type fastener above is out.
Don't tell the 10 or so moly wall anchors I have had holding things up on my foam insulated walls since 2007/08. Those moly expanding anchors will IMO work just fine in foam insulated walls unless the foam is wood type solid which would way a ton anyway. That small expanding area in those moly wall anchors will push the foam out away and you've already made a hole the diameter of the wall anchor in the foam to start with.
Larry
44,070 PostsLatest Activity: Sep 18, 2026
