btggraphix
Mar 17, 2015Explorer
PS: find a chart with normal full charge testing DC voltage for batteries (with type such as SLA, AGM, etc. Full charge after rest should be something like 12.8 or so. During charge it'll be in the 13's depending on three stage charging/type of charger etc. Resting voltage is lower that's why the rest period to get accurate numbers. When you do hook up to the converter/AC power you can then check what voltage the converter/charger is sending to the battery (frying it with 14+ volts?)
