JIMNLIN
Apr 22, 2020Explorer III
The 113 and 117 is the new international load index numbers that corresponds to 2540 lbs (113) and 2830 lbs for a 117 index number.
Its best to use the load rating stamped on the tires sidewall. Everyone doesn't have a cross over chart for those silly load index numbers..
For a daily driver that sees some dirt/gravel roads I like a AT (all terrain) type tread. I do have a full set of MT (mud terrains) in the garage for winter use when the county can't plow the roads or I need to work in muddy pastures/worksites. The MT with those large lugs and voids simply wear out too fast for every day use for me.
Your problem like any 1/2 ton truck with 20" wheels is finding tires with the tread pattern and load range like you want or need in your size.
