Bama bluejay wrote:
Thanks myredracer, lots of info to think about. alignment kit is called Correct track 11 double axle alignment kit. Our axels have been changed out to a 3 inch. much stronger than the 2 3/8 inch. which are the ones giving trouble. We've had very little wear showing on our tires.
That Correct track kit will make the trailer sit higher and effectively make the spring hangers even longer. With these lightweight flexible frames, the problems will be even worse. I wouldn't use them.
I agree with the 3" axles, the 2-3/8" toothpicks should be outlawed.
