NoEcho wrote:
scottew71 wrote:
I use Mr. Clean magic erasers on my Roo. They work great and you need minimal water. Easy to store in side the camper and very versital.
Does this remove the gloss? I was once told that the "Magic" in the erasers is that it is essentially fine grit sandpaper. I was reserved about using them as I feared the gloss paint would have "dull" spots.
Let us know!
Thanks
I can't speak for RV's but I've used them around the house and have noticed that they do remove a layer of whatever you're rubbing... ie on the wall it did remove some paint, on painted furniture it removed paint, etc. I use them very sparingly when nothing else will work. I don't know that I'd want to try them on my awning or other areas of the camper. Just my .02 cents.
