JamesTx's avatar
JamesTx
Water Faucet leaking.
Hello all,
We just moved into our 2006 Jayco Flight and know nothing about RV's
We have most stuff working but the sink has a constant drain going even when
Turned the handles are set to off.
Bad faucet im thinking. We're on city water but even with the pressure nearly off it still has a stream
Any ideas?
  • The other was old and crappy anyhow :) thanks, your probably right about the washer.
  • Remove the handle and replace the washers.
    Simple and easy. Just like at home.
    You may find a foreign object in the valve that keeps it from seating properly.
