2oldman wrote:
Lynnmor wrote:
I made a minor modification to the winterizing hose, and now can draw water from a container and send it to the fresh water tank.
It's difficult for me to tell exactly what you did.
To make it work, all I did was remove the guts (check valve) from the city water connection. Then put a tee in the line behind the city water connection and connected the winterizing hose to the tee. Last, I installed an inline check valve after the tee. Valve 1 was the original valve on the winterizing hose. All the rest of the diagram is the plumbing as manufactured plus the other modifications I made. You only need to look at the city water inlet, the tee and the check valve if you have a winterizing hose already attached. The only parts I needed to purchase was the check valve, a tee and some hose clamps. Outside I made up a short garden hose and connect it to a rolling water tank, but you can use any vessel that you want.
