This may be a no-brainer question, but so far I haven't figured it out. Since I winterized myself (compressed air method), I'd like to test everything out before our first trip. Problem is, I'm not...
If you just want to ensure there are no leaks in the system, you can always hook up your air compressor, pressurize the system and listen for air leaks. There is a way to hook up a pressure gauge if you want to do a leak down test properly.
You could also get a 5 gallon water container from WalMart and gravity fill your tank, then use the pump to pressurize the system.
