LOFAT36ExplorerOct 18, 2017Water flow29'-0trailer. When using the water pump it runs fine in the bathroom, good flow for the taps and toilet. But, when I turn on the kitchen tap the flow is very weak and the pump surges on and off. Any i...Show More
LOFAT36ExplorerOct 18, 2017Thank you that did the trick. I cleaned the aerator last fall but it plugged up again. Thanks again.
Related ContentNo flow from hot water tank Nautilus P1 systemWater pump?Why no hot water?No hot water flow, stopped up ?Water Pump
