bud121156
Sep 30, 2014Explorer
Water heater by pass question
This is a shot of my water heater and the by passes on a 2014 Coachmen Freedom Express. Should there be another cut off at the top, on the hot water out pipe? I understand the cutoff for the cold water in at the bottom, and open the cut off in the middle to allow the antifreeze to go up, but what keeps the antifreeze from going into the water heater at the top?
Someone on another forum suggested that on newer models, this is a check valve/back flow piece? Another said it appears to be a cut off with the handle missing? Any ideas?
