DWeikert
Nov 11, 2015Explorer II
downtheroad wrote:
Here is everything you need to know about: Water Heater by-pass.
>>>Click Here<<<
And yet, the single valve setup in my Northstar isn't represented there...
My camper is currently winterized and this valve is in bypass mode. I can only assume there's a check valve in the hot water outlet from the tank that prevents back flow.
To the OP, bypass the water heater before draining it then winterize the inside lines. This prevents antifreeze from entering the water heater.
44,056 PostsLatest Activity: Jan 12, 2020
