ADK_Camper
Jun 02, 2016Explorer
I had the same problem with my hot water heater. In my case it was the top valve (at the hot output). The solution was to cut out and replace the defective valve. You might be able to do the work yourself. Shark bite connectors are easy to work with and require no special tools. Just make sure you have clear access to do the work; some systems can have real cramped access.
44,066 PostsLatest Activity: May 13, 2026
