Ride S40T wrote:
And remember most water heaters have an inside "On" switch and an outside "On" rocker behind the outside panel where the water heater is drained.  Make sure that little guy is "On", too.
Only Suburbans ---outside switch is for Electric Element (OEM)
Inside switch is for GAS
Some RV MFGs will add an Inside Switch for Electric wired in series with outside switch...both have to be on for electic to work (unless burned out due to no water in tank)
Atwood uses Inside switches since 2004 models (combo elecric/gas)
Gas Only...inside switch
Think OPs Dutchmen uses Atwoods
