campermama's avatar
campermama
Explorer II
Oct 08, 2019
Water heater questions....
My water heater has 3 valves on it.
One on the red line at top = it's open
One in the middle = bypass valve closed
One on the blue line at bottom = closed
Should the bottom blue line valve be open for normal RV usage?
I'm just wondering, I am winterizing, drained water heater, shut off red line, opened bypass, blue already closed, will leave it that way. Is this correct?
Thx!
  • Instead of messing with the pressure relief valve, why not just open a faucet on the hot side? It’ll do the same thing.
    Something definitely screwy with the valve.
    I did open faucets first, but when I released the pressure valve water still came out.
  • opnspaces wrote:
    Did you check if your valves were only 1/4 turn valves? Or are they the ones that turn a few revolutions? If they are the screw type and you never touched the cold valve then it's still open and needs to be closed.
    They are 1/4 turn valves. I did the winterize, closed hot water valve, opened bypass valve, never touched cold water valve (already in closed position). All went well.
    I will check the cold water valve when I dewinterize and use the RV in a few months.
    Temps here dropping to 18 tonight :E
    That is due to 'loss of air pocket'
    Water level should be just at the tank opening where T&P Relief Vlave screws in......temp probe goes down into the water
    Air pocket is above T&P opening to top of tank.
    Air can be compressed and control pressure increases when heating water.
    Water SWELLS when heated so w/o air pocket pressure would increase
