campermama's avatar
campermama
Explorer II
Oct 08, 2019
Water heater questions....
My water heater has 3 valves on it.
One on the red line at top = it's open
One in the middle = bypass valve closed
One on the blue line at bottom = closed
Should the bottom blue line valve be open for normal RV usage?
I'm just wondering, I am winterizing, drained water heater, shut off red line, opened bypass, blue already closed, will leave it that way. Is this correct?
Thx!
  • 1/4 turn valves....valve handle indicates if valve open or closed
    Traditional valve that you turn handle until fully open or closed....valve handle could end up any position
  • If this is the type of setup you have with the blue line valve closed and still get hot water then that valve is defective.
  • Boon Docker wrote:
    If the blue line valve was closed you would not have gotten any hot water at the faucet, so it must have been in the open position.
    Normal RV operation:
    Red line valve open
    Bypass valve closed
    Blue line valve open
    Bypassed:
    Red line valve closed
    Bypass valve open
    Blue line valve closed
    Hmm, well unless the valve is somehow backwards it was in the sideway position (closed) and not in line with the line (open).
  • If the blue line valve was closed you would not have gotten any hot water at the faucet, so it must have been in the open position.
    Red line valve open
    Bypass valve closed
    Bypassed:
    Bypass valve open
