IMOC wrote:
Why is the switch "ON" position towards the bottom which is opposite the normal way rocker switches work. There must be some logic to it other then just messing with us...
Nope, there's NO logic at all. :R The slide switch on my Coachmen makes no sense at all - gotta push it IN to make the slide go out, push it OUT to make the slide go in. :S The awning slide is almost as bad - it's mounted vertically, UP to bring the awning in, DOWN to extend it out - could the mfg not have mounted it horizontally so I'd push the switch in the direction I wanted the awning to go? No, that'd be too easy. :R Yeah, I could remount the switches myself but then the engraving would be backwards - what a PITA. :M
