cavieExplorerJun 19, 2019water heatersWhy is it the all RV'ers have trouble with the HOT WATER HEATERS but nobody ever has trouble with a COLD WATER HEATERS??? Enquiring minds want to know!
16 RepliesReplies sorted by NewestShow MorePNW_SteveExplorerJun 19, 2019That and "unthawing" food from the freezer.... If you un-thaw then it will be frozen....BB_TXNomadJun 19, 2019Must be a slow day for someone today. :DOld-BiscuitExplorer IIIJun 19, 2019Technically it IS a HOT WATER HEATERAfter the initial heat cycle the t-stat closes at 110*F which by definition is HOT Water'Cold Water Heater' on initial heat cycle then 'Hot Water Heater' when reheating :B2oldmanExplorer IIJun 19, 2019See it all the time. It's a hot water tank, but not a hot water heater.Drives me nuts...like front windshield or glass window.Cocky_CamperExplorer IIJun 19, 2019I'm a plumbers son, and my dad calls it a hot water heater! It drives me insane!newman_fulltimeExplorer IIJun 19, 2019Cause once the water is hot they don't get why it won't get hotter :h
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Tankless water heater
