Tennessee_Nomad's avatar
Feb 19, 2014
Water hose quick connect question
Do any of you use the water hose quick connects found at the local home improvement stores. Looks like this -->clicky They look awfully handy, they also look like they may leak around the coupling? Feedback from any of you that use them would be appreciated. :)
  • I use a number of them with my water hose and filter hookup. Always but the better brass ones, all the same brand. I tried to get the ones where I bought both parts at the same time. You are right, the cheaper ones will leak, but I have no problem with the ones I have. If I do have a small leak, just twist them a bit to reaseat, and the leak goes away.
    To take them apart, be sure to turn water off, and release pressure in the hose or they will be very difficule to take apart, and will usually spray water on you.
