freddmcExplorerSep 04, 2016Water in FuelA friend recently had a situation where water in fuel destroyed his injector pump in his 2008 Ford F350. He said there was no warning that he had water in the fuel. How can one check to make sure thi...Show More
Turtle_n_PeepsExplorerSep 04, 2016Your friends 08 Ford has a totally different fuel system made by a totally different manufacture than your Cummins. I know of no way to check it other than putting a little water in the filter housing and see if it trips the sensor. I also would not worry about this too much with the fuel system you have. The CP3 pump is a pretty robust fuel system. The Ford system; not so much.
Related ContentWater PumpAtwood water heater problemfuel water separator filterFuel mileagefuel additives
