popeyemth
Oct 16, 2013Explorer
Inside the city water hose connection is a check valve that blocks the internal pressure from getting out
Just release all the pressure by turning off the pump and opening the faucets
Remove your pressure reducer and any strainer in the hose connection and you should see a plastic nipple that you push in and turn a little to clear
If that dosent work just remove it from the inside of the camper and replace
Good Luck, Mike
Good Luck, Mike
44,034 PostsLatest Activity: Apr 22, 2025
