- joeshmoeExplorer III
anutami wrote:
This how much junk I flushed out!!!
anutami wrote:
Noticed the caulking around the wiring penetrations came loose thinking this may be the issue??? Is the rubber not enough?
The amount of water you have Inside, I wouldn't think could slip past the grommet, unless it was puddling up to that point. I'd bet it's the pan seal or around the anode bung itself. - anutamiExplorer IIIThis how much junk I flushed out!!!
- joeshmoeExplorer IIIRay used a piece of eternabond. Eternabond to seal WH pan
- anutamiExplorer IIINoticed the caulking around the wiring penetrations came loose thinking this may be the issue??? Is the rubber not enough?
- joeshmoeExplorer IIIHey, Nolan
Just changed my anode 2 days ago also, but didn't flush the tank. I try to keep from flooding the pan area as I have the same problem, though not near as bad as yours. The lip of the pan is bent slightly so sealant didn't quite span the gap I think. Been that way from new. Found out when I went to flush the tank the first time. Haven't flushed it since for that reason.
The other possibility is a cracked bung. But as someone said, even the slightest fracture would show up. But you know how plumbing works. lol
The way these water heaters are installed...I'm not impressed.
Maybe scrape that sealant and lay down a nice, thick bead.anutami wrote:
jimh425 wrote:
Did you winterize correctly?
what's that? I live in san diego county and my camper is stored in and insulated garage.
LoL Not in So Cal.
EDIT:
Whenever I do anything with water on that side, I've made it a habit to go in and check with a flashlight. Ever since the flooding debacle with the tank filler leaking several mini-lakes under the sink cabinet, I don't take any chances. - ardvarkExplorerIf that water heater is under pressure, a small crack will look like a pretty obvious leak and Suburban water heaters are not leak prone, in my experience. Infrequently there can be a leak below the anode rod where the pan joins the tank, but those are normally in really old heaters with significant obvious rust.
- jimh406Explorer IIII was thinking a crack or other small leak unrelated to changing the anode.
what's that? I live in san diego county and my camper is stored in and insulated garage. - jimh406Explorer IIIDid you winterize correctly?
44,068 PostsLatest Activity: Jun 21, 2026
