JBarca
Jan 28, 2018Nomad II
Looking good Don,
I like your can of rubber spray. I'll have to get a can for pin holes in the Darco. I now use stainless staples if they are exposed to the weather. Found them the last time I was at the lumber yard.
I have found this product works really well repairing torn or cut Daro. Comes in various widths. I just ordered a 4" and 6" roll. I have used this on the bottom of my slide floor and still perfect since 2010. If you want it permanent, warm it with a hair dryer, and press firm. It is not coming off. Do not overheat or it will shrink it.
Flex Mend belly repair tape.
They use this in the manufactured housing industry where the entire bottom of the house on a slab is covered with Darco for patches.
I do use Gorilla tape some time too, all depends where I'm, using it. The warm it and press trick helps on the Gorilla tape too. The Flex Mend is thinner than the Gorilla tape but it is very hard to tear if you can.
