JBarca
Feb 13, 2018Nomad II
BurbMan wrote:
Our old Sunnybrook had a similar set up, they called it a "flush floor" slideout, so when it extended it dropped down and made a flat floor with the inside. When you retracted, it used a cam mechanism to raise the slide floor back up away from the main floor. This slide is straight in/out, was disappointed that the cheaped out on this feature.
Yes, that's it. I forgot you had the SunnyBrook. Yes, they used that same concept. It costs a little more to build them that way, but they work well.
Your flooring looks nice.
Your gaining... Keep up the good work.
John
