museumman
Jun 04, 2017Explorer
water leaks
I have been researching travel trailers for over two years off and on and am now within a few months of needing to make a decision. Just about the time I think I have it all clear on floorplan, materials, methods of construction, etc. I find my self back at ground zero, starting fresh. I guess I would truly be a salesman's nightmare if I were actually shopping at this point in time,
I feel like I know as much as I did when I started! About fifteen years ago I happened to be in a courtroom when a guy was sueing a company to recover the cost of replacing a leaking roof on a travel trailer. The dishonesty of the seller being sued, and who subsequently lost the case, was shocking. Brand new travel trailer not used for two years due to leaking roof and no resolution to the problem other than the owner paying for a new roof!
Since then I have become aware that perhaps water leaks are possibly the most frequently occurring issue with travel trailers.
I was reading a long discussion about aluminum vs wood framing and realized that the one common thread was that leaks were, once again, the real issue because of all the other wood parts.
I thought that perhaps buying a unit with a walk on roof would be a step in the right direction. I actually only looked at units with
roof ladders, assuming that they would have the strongest roofs. I am still not sure if that has any bearing on reducing the potential for leaks. Just seems to me that after all these years of manufacturing travel trailers, the manufacturers would have figured out how to build leak proof units. My house doesn't leak! My cars don't leak! My boat hatches and portholes etc. don't leak.
I have been a boat owner for many years and I have learned to do a lot of my own maintenance, some normal preventive and some innovative. I am beginning to think that one must accept the fact that constant care and maintenance is also a pre=requisite to owning a travel trailer. I.E. leak detection and knowledge of the best methods of prevention and repair etc. I assume that an airstream would be the best bet but then they are a bit out of my price range.
Ok, with that little diatribe, which manufacturer is on his game with solid construction?
