bobndot
Jul 17, 2018Explorer III
beemerphile1 wrote:
It is unlikely the low point drains will drain the fresh water tank, the tank should have its own drain.
It is very possible that the low point drains are draining the water heater.
Yes B re: the FW drain , true most of the time. I just found a sunseeker MH with a low pt drain petcock on the cold side. When I drained the line it just kept draining and draining and draining...…..:h
The freshwater tank is connected to it. It was explained to me that some new units are plumbed to drain the LP line as well when you drain the FW tank. I think it's designed that way to limit diluting the rv antifreeze during the winterizing process.
