tpprepper's avatar
tpprepper
Water Line Replacement
It seems that I did not get all of the water out of the main water lines last fall. Found the main 1/2" lines cracked and useless. I am going to replace them but was wondering if there was a "better" line to use instead.
The factory lines are the standard pvc type with glued fittings.
Is there a flex line that could be used?
Hope somebody out there had some experience with this.
Thanks
Vic
