poppin_fresh
Aug 26, 2013Explorer
It can probably be fixed if you are determined. The big question is where is the water coming from? If you dont fix the source of the issue, why bother fixing the result, it will just happen again.
Can you find any obvious signs of water infiltration? Are there cracks in the roof or obviously leaks around a marker light or other exterior feature?
