Padlin
Aug 29, 2013Explorer
LisaHemmeler wrote:
Bob, How did you lift the camper body in order to replace floor.
I had to drop the front of the frame enough to allow me to slide a new sheet of plywood under the side panels as I only had to replace the front 4' of flooring. The idea was to support the body while dropping the frame by lowering the front leveling jack.
There are bolts holding the trailer body to the frame, 10 or 12 in my case. I had to replace the front 4' of the floor which meant removing the front 3 bolts as they go through the sheet of ply involved, the rest I loosened enough to provide the clearance I needed. Removed most of the screws in the 2 front corner moldings to allow one to attach 2x4's to the corner frame that's behind the molding. You may or may not have to remove the lower edge moldings, mine were off or loosened enough to push out of the way to facilitate the new plywood. The newly attached 2x4's protruded 6" or so below, I placed a car safety jack under each and slowly lowered the frame about an inch giving me the clearance I needed.
If you are just going to attempt to get access to the underside of the plywood to dry it out, you'll need to drop the black membrane, which involves removing the lower moldings. The membrane is held in the moldings with what looks like putty tape (available from rv supply places), I did not separate the 2 except for the front and probably should not have done that one either. getting the exactly but membrane back in place under the molding is proving a challenge in that front piece.
Let me know if this isn't clear.
