dsmechanicExplorerSep 02, 2014water pressure reducerI have a 2015 premier 19fbpr, was wondering if i need to use a water pressure reducer like i did with my 07 surveyor? i have been using it but the pressure at the taps are weak.
ScottGNomadSep 02, 2014Get a $12 Camco "High Flow" (blue collar) regulator and it will be set for 50 PSi and give you all the volume you can use.
Related Contentwater pressure reducerPressure Reducing Regulator SettingWater pump?City Water Pressure ReducersPressure reducer for water?
