I have a 2015 premier 19fbpr, was wondering if i need to use a water pressure reducer like i did with my 07 surveyor? i have been using it but the pressure at the taps are weak.
PEX can handle in excess of 100# ......fittings, well not as high.
A water pressure regulator is a good tool.
Low pressure........ Could be clogged regulator Could be low CG pressure Could be clogged water filter Could be clogged screen/washer at city water connection Could be clogged faucet aerators
