oxygen wrote:
Have a new tt with black tank flush and wondering the flush is just a regular stream or series of small streams that clear around the entire tank and also why keep the black valve open when rinsing with this flush? Would think you want the water level to build up to rinse better.
thanks
There are some type of moving parts that spray the water all over. Two reasons to open the valve, first if the tank fills the spray will not reach the bottom but the most important is the bathroom/trailer will flood if you get distracted and forget about it. It is easy to be distracted as you are closing up, someone asks for help or stops to talk and the next thing you know is water is flowing from the trailer.
