augustpilot's avatar
augustpilot
Water Pump Help shurflo
2017 Rockwood with shurflo pump. Worked fine a week ago. Tried to use tonight . Turned on but did not pump, so did not make much noise. Water in tank, pump is connected with electric, filter is clean on pump. Took hose off inlet, put finger over pump inlet but felt no suction. Never had a problem with it before. It is 1 and 1half year old. Thanks for any help.
Jim
  • You could try disassembling the pump, cleaning all the parts and reassembling. These small diaphragm pumps are real susceptible to any debris inside.
    A good experiment is to route the pump's inlet into a container of water held up above the inlet location. Open a faucet and see if the pump will draw the water from the container.
