Just bought a 2003 Coachmen Clipper 116 Sport Plus pop up pull behind. It has a fresh water holding tank. I cant seem to find the location of the pump. Reason for looking, No pressure or sound of the...
Water pump usually controlled by switch - turn on a faucet and then start flipping switches until you hear the pump turn on. In my friends Coachman the water pump was located inside a cabinet but you had to remove a back panel inside the cabinet to actually get access to the pump.
