Deano_1ExplorerOct 18, 2021Water pump question Where would I add a winterization kit or use an existing fitting to add antifreeze to my system? Is the white plastic circle to the left of the pump a filter? ThanksShow More
BumpyroadExplorerOct 18, 2021looks like it could be. I haven't seen/had one that looks like that however.I assume that there is some way to remove that top piece?????bumpy
Related ContentWater pump?Water PumpWhy no hot water?Water pumpWater Pump Failure Traveling To The Eclipse
