msiminoff
10 years agoExplorer II
Water pump timer
This is a very simple an inexpensive mod that I has been on my to-do list for quite a while... I added a time-delay relay to my water pump's electrical circuit so that the pump will turn itself off after a preset amount of time.
As part of the job I added a pushbutton switch in the bathroom for those times when we forget to turn on the pump before closing the door. In addition, I swapped out the rocker switch on the TC 's electrical control panel for an identically sized one that is momentary rather than on/off.
I chose a Hella 996152131 relay which has a user-selectable delay from 0 to 900 seconds. There are less expensive relays out there with the same functionality, but this one is plug-compatible with the Hella relay I installed ~10 years ago, so that made it a no-brainer.
At the moment the timer is set to about 14 minutes which is longer than it takes to wash the dishes, shower, or use the restroom.
Here are a few pic's...
The time delay is selected using these dip switches and trim-pot.
I found a small chrome momentary pushbutton at Napa so we can switch on the water pump from inside the bathroom.
Cheers,
-Mark
Cheers,
-Mark
