joeshmoe's avatar
joeshmoe
Explorer III
Sep 05, 2014
Water Pump Was Left On
Apparently, my wife bumped the switch and never noticed it. She was cleaning and tidying up with the A/C on and didn't hear the pump. Later, I went inside, saw the switch light on. Reached under the step and placed my hand on it. HOT! Real hot. Must have been running for a good 2 or 3 hours non-stop. I shut it off and and let it cool. Put some water in the tank turned and it on. Seems ok, except it seems to cycle a lot more often now. So, how much life was taken off of it? Should I go buy another to keep on hand just to be safe? It's almost brand new. Not much use at all.
Seems like a good reason to not completely drain the FW tank again
  • There are no impellers. The pump is a hydrostatic design - think of making arm-pit noises ;).
    That's why it doesn't hurt it to run dry. There's nothing rubbing inside.
  • If it runs dry could it wear the impellers so the system loses pressure back through the pump causing the pump to cycle occasionally?
    Just a thought.
    Steve.
  • They are designed to run dry.....doesn't need water to act as coolant. Diaphragms only move about 1/8" total.
    Didn't get hot enough (motor) to trip.
    Cycling more probably due to not getting all the air out of lines.......opening all faucets/showers (hot/cold sides).....toilet etc and purging lines of air.
    It'll be OK
  • Mine ran dry for more than two days - that was 5 or 6 years ago and it still works great to this day.
    They are designed to run dry. I wouldn't worry about it.
