Water pump not working. Is it froze up after very cold winter? I do not see a fuse for it. Will it be hard to replace? Will wiring have a socket or will I need to cut and splice wiring? I have a Ascen...
Typically, they are not hard to replace. You normally have hose clamps to make the plumbing connection and twist connectors for the electrical. It is fused, so make sure you have 12V going to the water pump when the switch is turned on before you spend the money for a replacement.
