Water pump not working. Is it froze up after very cold winter? I do not see a fuse for it. Will it be hard to replace? Will wiring have a socket or will I need to cut and splice wiring? I have a Ascen...
There will be a fuse for it. Check the voltage like TucsonJim said. Remember, the voltage is switched on and off by the pump switch on your monitor panel or somewhere.
If you can not find the fuse I would contact Chalet... You do need to know where your fuses are located.
