My pump isn't working. I have power going to it but it doesn't run. Its a new camper, a bit over a year old and the only time I used the pump was last fall to winterize it. Any ideas??
Could also be the pressure cutoff switch built into the pump. Try bypassing it. If it's a ShurFlo pump the switch is available as a separate part for way less money than a new pump. Not sure about other brands but suspect that the switch would be available.
