tnrv_er
Nov 04, 2016Explorer II
water pump
My pump isn't working. I have power going to it but it doesn't run. Its a new camper, a bit over a year old and the only time I used the pump was last fall to winterize it.
Any ideas??
Any ideas??
tnrv'er wrote:ksg5000 wrote:
When my pump when out I first checked the fuse - then tested the pump by applying 12 volt power directly to pump (it worked) - then I checked the pump switches in kitchen/bathroom etc (they worked) - and concluded it was the pump relay which was the problem. The relay (which allows bathroom/kitchen/shower switches to operate pump) isn't that expensive ... but it's location varies on each rig and is often a PIA to find/replace.
My dealer told me to do what you are recommending also. I'm gonna try that now.
Dick_B wrote:
Do you mean that the power is actually getting to the pump or is there power at the circuit breaker box?
Is there an inline fuse in the power wiring?
