jeff467ExplorerOct 05, 2017Water pumpI am going to replace my 32 year lold water pump. Is it better to g get a pump that is rated for 3.0 gpm and 55psi or 3.5 com and 45 psi?
Dick_BExplorerOct 06, 2017I'm thinking the lower flow rate which would enable the pump to operate at more of its maximum. If the pump has too high a capacity it will not operate smoothly at the lower flows. I guess unless it is a `smart' pump.
Related ContentCummins Water Pumpwater pump replacementWater pumpNo pumping waterWater pump chattering
