jeff467ExplorerOct 05, 2017Water pumpI am going to replace my 32 year lold water pump. Is it better to g get a pump that is rated for 3.0 gpm and 55psi or 3.5 com and 45 psi?
joshuajimExplorer IIOct 06, 2017I'm not sure it matters much. Most fixtures are derated to about a gallon a minute. Higher pressure will pass more water, higher volume not so much.
Related ContentWater PumpWater Pump Failure Traveling To The EclipseWater pumpSlow water/noisy pumpwater pump
