Chad_JenExplorerJun 03, 2018Water pumpOur water pump is on (pulling fresh water from the tank), we recently went to use the water at the faucet and nothing came out (even though the pump switch was on). We tried a little while later and i...Show More
rbpruExplorer IIJun 03, 2018That is strange. I guess I would look for a line kink or blockage. Check the pump filter. Ours it mounted on the pump.Good Luck
Related ContentWater PumpWater Pump Failure Traveling To The EclipseWater pumpwater pumpSlow water/noisy pump
