oldguyrich's avatar
oldguyrich
water pump
i have a 2016 Coachman apex. i can not find the waterpump. anyone have access to schematics?
  • My 2 trailers has been pretty much under where the city water inlet is. My fresh water tank is up front of the trailer and the pump is all the way in the back behind a panel in the rear bath where the water filter is. The city water is on the rear end of the trailer.
    On my old trailer, the tank was up front, the city water is on the side of the trailer just above it and the pump was under the kitchen sink right below it.
    Good luck!
    Mitch
  • Check under the refrigerator. They love to stuff things into that space.
    Bill
  • yep, Turn it on and let it run. Go find it. You will need a #2 square drive to remove some screws in a panel. look under a drawer. under a bed. My trailer it was behind a panel in the pass thru compartment. In my 5th wheel it was in the open in the basement.
  • TT's dont generally have schematics. Like a house, they are simply wired as needed.
    Can you hear the pump run? If so, leave it running (dry is fine) and track it down.
